Remain OBJ mesh original position when importing
It looks like when Fusion imports OBJ data that the position of the mesh is being ignored
centereing objects in the world space.
This is not an ideal situation. When I have 3D data in a different application I would like
to remain the position of all the mesh data when importing object by object into Fusion.
External app - pay attention to where the meshes are:
Fusion: both meshes imported in two steps are centered in the world xyz = 0.
4 Comments
cekuhnen
I just tested the new Fusion build and saw that still when you import multiple OBJ objects you need to per hand realign them. This is not really ideal at all.
Could you please remain the xyz position of obj mesh files when importing!
cekuhnen
The new update got out and still when OBJ data is imported the position of the mesh information is ignored. All CAD applications I work with maintain this data. For exchanging 3D data it is very imparative that the position (rotation) will keep intact and not reset.
Can you input this feature? It should not be that hard - it is also a standard in other packages.
deyop
Status changed to: オートデスク審査落選
We have a task (FUS-11262) that relates to the positioning of meshes when inserted.
colin.smith
