By which I mean you should throw out the current drawings capability and start from scratch.
I had to do some renderings for a patent application and noticed that this was there now so thought I'd try it.. to my great frustration and disappointment.
On one hand, it can make very cute renderings so that's something.. on the other, it's incomplete and broken to the point of being useless.
In almost any use case I can imagine, I'd want either independent sheets with different / standard views (Front, Top, Side, Perspective, and optionally Bottom, other side and other perspective angles for things that aren't symmetric).
By default though I'm stuck dropping one face into a random location in the drawing, then adjusting the scale to get it roughly to fit which immediately breaks the positioning (unless the user is clairvoyant with precognition, they'll have placed it in a location that will end up overlapping the drawing with the key or having it go off the page).
It would be completely trivial to just open it up and magically see the standard views with reasonable scaling and dimensions and tolerances (if they were actually there - note they're not) keyed properly.
On top of that, all of the view orientations are impossibly wonky.
Right is somehow actually Front but rotated 90º. Top is another face, I don't think there's a single view angle that I tried that actually corresponded to the ones in the design. How can the orientations be that far off?!?
Once everything was in there and in a reasonable orientation (after restarting a couple of times due to hangs and crashes), I had to delete the key - obviously to do that you just click the «delete» tool but that only selects the object to delete and it was only through random fumbling that I was able to discern that I needed to do a two-finger-click and then hit «OK» to actually delete (I've still not managed to figure out how to move a drawing).
There is no way to select the line or filling style.
Aside from just working as engineering drawings [if a bunch of things were redone and fixed], these drawings are sooo close to something that could be used for a design patent application yet sooo far away.
Selecting hash filling options, line styles, and 2D representations of 3D shading would go a huge way in that direction.
I feel like I'm taking crazy pills because it seems insane to me that this is actually an «Ultimate» paid edition of a product from an established company. Sure charge and make money for it but at least label the thing «alpha» / preview-release.
