Re-Editing a feature does not allow to choose multiple profiles, faces, etc.
When editing a feature, I usually can only select one face, profile, ... and have to clock "ok" and re-edit the feature to choose more even though the focus in the edit window is still on the "Profile" selection.
For example create a sketch with three rectangles. Stop the sketching and extrude one of those rectangles. Press Ok to finish the extrusion.
Now try to edit the just created feature and add the two other rectangles to the extrusion. Fusion360 allows you to select or deselect one, but then only allows you to change the dimension anymore even though the "Profile" selector still has focus (is marked blue in the edit window).
5 Comments
HughesTooling
If you hold the Ctr key down you can select more profiles. Om a mac I think it's the command key.
Mark
Hm. I had tried thad all week, but it didn't work. Now after clicking around everywhere, moving the value box around and trying everything else, it suddenly does.
But now I can't orbit anymore using two-finger trackpad-swipes plus shift.
Something is fishy with my GUI... 😕
I'm having the same issue here and its driving me INSANE!
I'm trying to quickly edit an extrusion feature and it only lets me select one profile before it brings up the thickness dialog box and bars me from doing much else. So I click OK, look at a spinning beach ball, zoom out, zoom in, edit feature, spinning beach ball, try and select another profile, etc.
PLEASE PLEASE PLEASE FIX THIS!!!
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
