"Activate" the origin planes when starting the "Offset Plane" command
When I start the Offset Plane command in Fusion I would like to see the visibility of the origin planes temporarily turned on as I am often offsetting directly from an origin plane and typically keep their visibility off.
This feature already happens when you create a new sketch with the origin planes turned off so I'd just like to see similar functionality with the offset plane command.
1 Comment
promm
Status changed to: RUG-jp審査通過
John,
Thank you for you idea, this is getting archived due to lack of votes.
Cheers,
Mike Prom
