public link status indicator
Add an Icon to the myhub online website and to the Fusion 360 Document Browser to visualize if a file has already been shared or if there is already an active public link. Also a possibility to delete all public links in a project would be cool.
5 Comments
It would be importent to have a direct overview like this about public shared designs.
Thank you for adding such a feature.
yanouk73
There is also a problem, when a link is done, if you want to delet the file, you cannot, end of discussion... but we should be able to find the link is with wich oder file and then we should be able to break the link then delete the file.
Same thing with link with a drawing... when we want to delete older files, no is not a good answer.
Yan
I just got clued into the 'Easter Egg' link that exists in the F360 desktop app, to the myhub page.
I had the same problems finding it.  No links anywhere....that you can see.
I suggest adding on to the right click menu of the drawing in the data panel AND one under the list of links under my user name in the upper right corner.
For the meantime, I will share that the name of the Project in the project panel is a link to the myhub page.  This is a super easy upgrade that will do a lot to reduce the disconnection between all the capabilities that Autodesk is stitching together.
Preston.
TTechN
it would also be nice to have a map across all projects which have shared links - otherwise I can only see the links in the working folder.
Thilo
pavmed
Great feature suggest! My vote goes here.
Pls, support my idea of No download by default when sharing.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/share-public-link-view-only-by-defau...
