on of the main reason why I do not like tools like Keyshot is because they are often inferior when it comes to UV mapping.
here is a single surface: easy to texture map a single nurbs surface
now when the surface is a poly surface Fusion gives up:
there should be an option to make those 5 surfaces a logical group and stich em together for the UV projection.
