Because the WCS Zero point is a driven constraint in situations such as when you set the WCS to rely on the Stock, it is possible to modify the part and incidentally move the WCS without knowing it. This can lead to severe real-world crashes when the zero-point has unexpectedly moved. I propose that a warning be displayed any time the WCS moves from any position after the user has created any Setup.
