Print function
Print function
Hi. There needs to be a print function added to Fusion 360. It is crazy that I cannot just simply press print to quickly and easily print a sketch or a completed part. I always have to export or save it as PDF first. I should be able to print directly to a laser cutter and not have to use another computer program like Illustrator to print to the laser. All other CAD software allows this. PLEASE PLEASE add a print function.
2 Comments
hahaha... yes, the printing options in Fusion... 🤗
daniel_lyall
You can output directly to a laser using the manufacturing workspaces, or highlight and then right-click on a sketch and save as a dxf then load that into the laser as you already know.
Yes, a Print sketch would be handy.
You can if you want to use the sketch to make the toolpaths for a laser in the manufacturing workspaces it is better to use a sold.
