Annonces
annuler
Affichage des résultats de
Afficher  uniquement  | Rechercher plutôt
Vouliez-vous dire :
Print Function?
Print Function?
Maybe this is a dumb question/request but I would like to be able to print dircet from Fusion. Currectly the only way I can figure out how to do it is creating a file, (PDF, JPG etc) and then printing it in annother program.
7 Commentaires
TimeraAutodesk
Statut modifié en : Future Consideration
bkgoodman
This is kind of a HUGE ommission!!! Smiley surpris
utekcnc
Support it and I need this.
agordon
The current suggestion (use PDF output) is flawed.  PDF output from F360 does not render correctly in Reader DC 15.x (latest version as of 12/16), and details are overwritten and text size is often different.  The flaws in Adobe's rendering of PDF format graphics containing text strings are well known, and so it should be avoided.
The second suggestion, use DWG is fine if you have Autocad installed, but what professional package sends users to another package to print drawings and WIP output?  To say nothing of the free DWG readers that do not work well.
Both Win and Mac OS both support print calls very simply ...
TimeraAutodesk
Statut modifié en : オートデスク審査落選
Non applicable
A print function is stroooongly recommended.
keqingsong
Statut modifié en : Implemented
Good news! This is now available in the latest version of Fusion 360! https://www.autodesk.com/products/fusion-360/blog/december-5-2017-update-whats-new/
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
Proposer une idée
