The problem I see with slide edge is 2 fold
- The effect of sliding an edge is not seen when you move the edge. You move the edge around to affect a change but you cannot see the effect until the model rebuilds. This means very slow editing. Love to see the effect in the surface in real time or at least a higher quality simplified wire frame.
- This tool should be used all the time alternating between other transform operations. digging through the menus is slow moreover it erodes the modelers flow by refocusing the tool rather than the work.
PS thanks for this tool.
