Prevent / disable preview of best-guess boolean operation
It would be good to be able to turn off Fusion's attempt to guess one's most likely operation when creating geometry such as a primitive or an extruded sketch. If it decides to try and join many bodies, it has a tendency to bog down. It also creates an opportunity for user error if one is not paying attention. I often find that my entire model is glued together, and have to go back into the history to figure out which feature was set to JOIN, instead of NEW BODY.
One solution might be the ability to make NEW BODY the default operation, and selectively disable the contextual operation-guesser. The simplest way would be to make any operation type selecton made AFTER selecting the tool, but BEFORE starting to generate geometry, "sticky." This would seem to be a llow cost solution, since it is only a behavior change, and wouldn't require new graphical elements.
3 Comments
ThilaknathRao
In general all previews should be able to "disable" from the application options. On certain operations it takes a long time to just display the preview when I am not interested and would like to finish the command.
For ex., attempting to pattern a patch it displays the preview as I enter the number and spacing which takes a lot of time.
-Thilak
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
