Press Pull To
Press Pull To
I really like the ability of extruding "To" something.  It would be great to have this option within the Press-Pull command as well.
6 Comments
odolyte
brianriordan
Odolyte,
Unless I'm missing something, this is an example of the Extrude To capability- which I REALLY like, but I want that in the Press Pull command.  Press-Pull works differently than extrude.  I can Press-Pull a curved face, and can extend existing geometry in a different way that Extrude does.  I want the option to Press-Pull To something, the same ability as the Extrude To, but with many different effects.
odolyte
Sorry, ' didn't get it. This would be a nice idea. Quicker than pull then cut the "excess" with the other body.
Otherwise you can still circumvent this by creating a sketch on the face you want to pull and make an extrude to with the join option.
It does work for me.  You just have to drag the arrow a bit--then you can select the face. It will pop-up 'Snap To...' Click the face & you're done! Smiley Happy
odolyte
@Anonymous:  No it does not. It works only on parallel faces. See the difference here :
https://screencast.autodesk.com/main/details/402abd47-8f74-47ce-b53e-2b9585aacffa
TimeraAutodesk
Status changed to: RUG-jp審査通過
Thank you for your idea - this is getting archived due to lack of votes. Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers some more support from the community.
