Press L again to create new line
A really simple one, when you drawing a line and you want to start a new line, just push L to start a new line.  This would be similar to illustrators' pen, with that if you have an active pen line and you push p again it commits the vectors already drawn and starts again.    instead of having to press enter or click the checkmark just push the L short cut key to commit the already drawn line and start a new line.
Sometimes it's the little things.
2 Comments
HughesTooling
A small problem with your request, how's Fusion going to know if you press L to start a new line or because you want to enter a parameter name in the dimension field? I guess it would sort of work as long as you don't move the mouse from the last point.
Here's a couple of tips. One, if you double click when you add the last point it finishes that chain of lines and leaves the line tool active for the next chain or you can right click and select Repeat line to finish the active chain leaving the line tool active. The right click trick works with a lot of tools, sketch and modeling.
Mark
ericinthecircle
Cool thanks for the response and tips, I will try that out.
