Preserve selection set when initiating a feature
 This, to me, is a bug report rather than a feature request.  I will select 8 continuous faces forming a surface, and select for example push/pull, and then the feature dialog comes up and only one face is still selected.
Same thing in sketches, if I want to offset sketch entities and I select 6 lines/arcs in a chain, and select offset, it only preserves selection of one entity.
2 Comments
I just realized this even affects the Measure.  If I select two faces and then click Measure, don't I want to know the distance / angle between the two faces?  But I have to re-select.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to lack of votes.  We have preselecting of sketch features in our backlog, but I have not changed this to accepted because the first part of your request is a separate request.
Cheers,
Mike Prom
