Point at intersection of spline and plane
Its currently possible to make a point at the intersection of a linear entity and a plane, but not at the intersection of a spline and a plane. This makes construction of lofted objects using splines for both the sections and the rails very difficult. There is a workaround, or what should be a workaround, by making a square section body using the linear splines and intersecting the planes with the body, then creating points where the entities created intersect the normal plane, but the points don't seem to be on the spline, even though it reads as coincidental.
1 Comment
Cette fonction manque énormément.:
Elle rend les constructions à base de profil très difficile. (comme les fuselages et les empennages de planeur ou avion) .
Fusion sait déterminer le point d'intersection entre un plan de construction et une courbe puisque cela est utilisé pour placer un plan sur un path, courbe ou spline.
Pourquoi ne pas avoir cette possibilité dans la fonction Point at edge et plane ?????01.png03.png04.png
