if you are in model workspace you can use user defined parameters e.g. for sketch dimensions, dimensions of objects etc..
This is very comfortable. But unfortunately parameters are not available in the CAM workspace.
Even if I create parameters in the model workspace I cannot access them in the CAM workspace e.g. inside toolpath settings.
Lets say I have 8 toolpath. 4 with Lead-In radius 4mm and 4 with Lead-In radius 6mm.
If I later want to change the 4mm to 10mm I have to to it 4 times - for each of the 1st 4 toolpath one time - this is really time consuming.
Better would be to use the parameters. Then I can just change the parameter and all toolpath that use this parameter will update.
BTW: I know the 'multi-edit' feature where I can edit multiple toolpath at once, but this sheet is very big und uncomfortable to use.
I would prefer parameters for CAM as well.
Thanks!
