This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Pin connector in Fusion 360 simulation
would like ability to create a pin connector in Autodesk Fusion 360 Simulation workspace.
Pin connector should work like this: you choose two cylindrical faces and Fusion 360 creates this connection:
There's a very stiff beam, and each of its tips is connected to corresponding cylindrical face with rigid bars. Beam tip is located on hole axis at the center of cylindrical face.
This connector would allow cylindrical faces remain coaxial.
Options should be available to allow or contrain:
- relative trasation of the holes in axial direction
- relative rotation of the holes respect to their common axis
Fusion 360 should allow to evaluate axial, shear forces, bending and torsional moments on the beam element in order to use this data to evaluate pin failure.
