Patterns with Features
A good idea to be developed for the next update would be that the option for the [patterns to copy some of the features of the component. For example, if the component has a joint, the pattern could give the option to copy the joint of the component. That way a lot of time can be reduced because if I want to pattern a part component 100 I will have to create the same joint 100 times for the 100 part components.
Regards
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
