A check box should be add in pattern (rect or circular), so it generate only one part, that what we are looking for in most of the time, it reduce drasticly the object tree list and the number of operations too.
When you need to combine in a separatly opperation, you have to select the bodies, it generate many manipulations and if you do many pattern, this become none productive.
Yan
