Path Length Constraint
For constructing models based on paper or sheet metal, it's really important to constrain models based on the length of curves/lines instead of only the distance between two points on the curve. Not having this feature makes it virtually impossible to correctly model a curved piece of paper / sheet metal based on the size of the original sheet. This is also really important when interacting with belts around pulleys.
