Patches menu
Patches menu
Patch menu is not necessary. I don't find it useful. You could use meshes, patches and solids all in the same environment with no need to switch from model to patch. I also found this I-DEAS feature very usefull: parts became solids only when all surfaces were stitched. If this condition was not satisfied you had a sort of quilt with no volume.
3 Comments
cekuhnen
OnShape offers loft extrude etc as one tool and then offers surface or solid as a result!
However Fusion offers unlike OnShape also tools that only work with surfaces - so it makes sense that they keep the menu separated.
I would rather vote for name changes:
Solid and Surface
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
