Parameters in Text
Parameters in Text
There should be some way that you can use parameters in text equations just like you can in inventor. I have to make tools that are very similar to one another and they need to be engraved based on on the dimensions of that tool. It would be a thousand times easier to be able to change one number (the size of the tool) and in addition to the dimension changing, the text changes too.
Another thing I would like to point out is although you can somewhat constrain text in Fusion, it seems to remove any and all constraints when I just want to change the text property and not things like height and angle, which is a huge pain when trying to center text.
I saw this post here a month prior but it it got no responses so I thought I'd throw it out there again.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/autofill-text-field-based-on-a-param...
This issue with text is by far my biggest gripe with Fusion 360. Its amazing software but if this was implemented it be the best hands down.
25 Comments
r.eichlerXS4US
Observer
The version number only updates when you save though, so when you export to
STL the number might be inaccurate without further logic.
rodrigo.alvarez
Yes.
For proper version control I always save and then export.
In software-land I always setup my builds so that the git/version is inserted into the executable. For sanity the string includes a flag that shows if the build was done Ruth a clean state or a dirty state. The same thing could be used here. For example v298 or v298*.
Does anyone know if Autodesk is still monitoring these threads & using the feedback to drive features & updates?
I have not had any reply to the PM I sent to @keqingsong
C.Nicks
Bump
Any updates on this?
I'm new to Fusion 360 and when I went to add text I thought this was a no brainer considering parameters can be used in so many other places.
I would think adding a link to a parameter and grabbing the result would be super simple.
Having a 3D printer (Prusa i3) next to my workstation allows me to prototype and test fit my designs very quickly, but it also leads to a lot of prototype parts sitting around my workspace. I add version remarks (text) to the objects before I print them, but I don't always remember to update them. It would be nice to have parameters that can be tied to the file version number or an automatic date. I would want the sketch text to update to reflect these properties at every file save or "Make" operation. Being able to compare a Version 8 and a Version 10 on my desk by seeing text on the parts would be great for design management.
