There should be some way that you can use parameters in text equations just like you can in inventor. I have to make tools that are very similar to one another and they need to be engraved based on on the dimensions of that tool. It would be a thousand times easier to be able to change one number (the size of the tool) and in addition to the dimension changing, the text changes too.
Another thing I would like to point out is although you can somewhat constrain text in Fusion, it seems to remove any and all constraints when I just want to change the text property and not things like height and angle, which is a huge pain when trying to center text.
I saw this post here a month prior but it it got no responses so I thought I'd throw it out there again.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/autofill-text-field-based-on-a-param...
This issue with text is by far my biggest gripe with Fusion 360. Its amazing software but if this was implemented it be the best hands down.
