I set up a parameter and accidentally ascribed a unit to the expression I wanted to remove the imperial qaulification for the number so the variable was the numerical amount of items in a pattern. I couldn't delete it because it was being used so I had to go back and redo all the instances were I referenced that parameter. I should be able to just open that original window when I set up the parameter to adjust it accordingly.
