paper (package design in sheet metal)
Obviously the physics is a bit different, but it'd be great if the sheet metal library had papers and card stocks for packaging design
It'd be awesome to import die lines and build my packaging or design the packaging in F360 and export die lines
1 Comment
My needs aren't quite at this level, but I'm currently having to work in Illustrator to design some foldable houses. It's doable, but Illustrator is not parametric, and so when I do things like scale the size of a wall, all my tabs and slots scale as well, but they were sized for the 300ish gsm paper stock that I'm working with. I'm sure I can work something out on my own with the rules system, but ++ for having some basic starting points in F360.
