Override joint limits on linked assembly
I would like to change the joint limits within linked assemblies.
Example: I have a hinge with a joint that is limited from 0 to 180 rotation. I place that hinge in an assembly and would like to limit the joint in that instance of the hinge to a maximum 90. Currently I need to create a new local joint and add limits.
