With Mulit-Setup CAM operations, such as machining the opposite sides of an object...
When I attempt to highlight one setup, I get inconsistent output results. Some times I get G Code from both setups, other times I get Code from only the highlighted one. After quite a bit of playing with it, I can't find a way to produce consistent results. In fact, some times without changing the setup highlighting, I get different results when producing the code for a second time!
It would be nice to have some way of specifying that you want only the code associated with individual setups.
