Origin point from browser as center for circular pattern
I have a sketch with several points at the origin point. This means that I have a few construction lines starting at the coordinate system origin point. Now I want to add a circular pattern. I select e.g. a circle, then I want to select the center point. But here comes the problem.
Since there are several starting points stacked on the origin I cannot select the origin point as center, I only get the point from the top of the stack.
Now I thought I could select the origin point from the browser, but this don't work. I can click the origin in the left browser but 'Center Point' inside the 'Circular pattern' popup window still shows 'no selection'.
So please make the coordinate system orgin point from the left browser selectable as center point for a circular pattern.
Thanks!
3 Comments
TrippyLighting
Of course you can select the center point as you pivot point.
If you want to select a particular one of the stacked ones, you can hold the left mouse button a litel loner than just a click with the cursor hovering over it a littel longer and you will be presented with a list of al the points in that location.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
