When manufacturing multiple instances of the same part, this is possible to do with pattern or with multiple WCS offsets. It is also possible to combine both, to have multiple instances of the same part at each WCS offset.
To reduce the number of tool changes, it is possible to select Order by tool option. When using both multiple WCS offsets and pattern at the same time, the Order by tool option does not work as it should.
Only one instance:
T1
T2
Four instances using multiple WCS offsets and Order by tool option:
T1
T1
T1
T1
T2
T2
T2
T2
Four instances using pattern and Order by tool option:
T1
T1
T1
T1
T2
T2
T2
T2
Four instances using both multiple WCS offsets and pattern at the same time and Order by tool option:
T1
T1
T2
T2
T1
T1
T2
T2
