option; two data panels side by side ( like window explorer )
Proposed workflow ;
  1. Your looking for an old file or component to add to a your latest assembly.
  2. You go digging for the old file in Data panel. Find it. Great!
  3. Would be good to have a simple check box or button that allowed a duplicate data panel to nest parallel ( like snapping two win explorer panes side by side )
  4. Then simultaneously I can navigate to the latest assembly as well > open it from the right pane > Drag the old component in from the left pane.
I do not see this functionality, therefor
Current workflow:
  1. Find old component and then open it.
  2. Find the new assembly file then open it
  3. Then "save as" the old component into a new directory creating an unwanted duplicate.
  4. Then drag that newly saved "duplicate" into the assembly. This might work in a lot of cases, but it does not help with staying organised with document control.
If this feature exists, then i missed it. As a lot of folks here agree, data panel lets the software down. Its nuts and worth a separate post, to "filter by type" how can that not be present.
Please bump this up so we can get this software brought out of 'Beta' thinking.
Chris
Flynn Product Design
