This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Option to set G95 for Feed Rate in Post Process
Sir / Ma'am,
I am new to Fusion 360 and undertaking CNC training at an institution that likes to run "Feed Rate in Units per revolution, G95" instead of "Feed Rate in Units per minute, G94" when students are machining.
I believe Feed Rate in Units per revolution, G95 is desirable as it "relates feed more closely to chip load, as well as having the ability to maintain the desired chip if the spindle speed is varied during the program, or by the operator using the spindle override control".
I have noticed that Fusion 360 already calculates 'Feed per Revolution' in the 'Feed & Speed tab' when setting up a new tool in the Library as well as reflecting it in the 'Tools tab' of a generated tool-path in a 'Setup'.
SUGGESTION: Is it possible to make an option within Fusion 360 to select and set G95 (Feed Rate in Units per revolution) as the preferred feed rate method (maybe in the 'Program Settings' area in the 'Post Process screen')?
Thank you for your consideration.
Peter Tooley
3 Comments
HughesTooling
You can do this already, you need to set the tool up for feed per rev.
Mark
HughesTooling
You can set the default for turning ops by right click in an input field and select make all default. Make sure all settings are set to the defaults you want first.
Mark
Thank you to HughesTooling for their suggestions.
I noticed these solutions were for CNC Turning.
Is there also similar options to be used for CNC Milling operations?
Thank you again.
Peter Tooley
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
