Option to Auto Ground Components
Having the option to Auto Ground a component when you create it in the workspace. This is so we dont move components slightly by accident while making assemblies!
1 Comment
mickmac06
Coming from an Inventor background where I almost exclusively used the multibody workflow, the option to auto ground components would be a massive improvement. I don't understand why a fully constrained sketch can still be moved once it is extruded into a component. I appreciate I can right click and select 'Ground' but you cannot multi select components to ground, and grounding the assembly will not ground the individual components, which can still be moved. To individually ground 300+ parts is very time consuming.
