Operations like scale, combine and others should allow using selection sets
I am working with numerous componens and right now to scale a component I need to go in and manyally select every body that I want to scale, even if I just want to scale the whole component. Selection sets sounds like the right thing to use for stuff like that, but it doestn work. I would like it to work that way
2 Comments
Hola, I am a little new in fusion 360, but maybe my suggestion can help you, I suffer the same problem than you, how I fix it, I just get my view to get all bodies  and components together, and like that I do everything, I hope help you bye
gato from Costa Rica
promm
Thank you for your idea, this is getting changed to future consideration.  When work gets started, it will be changed to accepted.
Cheers,
Mike Prom
