Hi!
While using Fusion, I occasionally find this problem where after offsetting a sketch line, to make a second offset (like for lids that save material), the second offset needs to be made directly from the original sketch line, not the already offset line. Fusion recognizes attempts to do this and instructs users to simply create the offset from the original. This is a minor problem, but simply adding double-offset functionality would greatly increase the time it takes to create lines, not experiencing the problem, then trying to work around it. I know you are busy, but I hope you consider this.
Levi Giesbrecht
