Show only
Search instead for
Add angle input for offset plane, not just distance so you could offset 300mm @ 5deg for example. I always find getting planes where I need them to be one of the trickiest things in fusion.
I agree. Maybe combine 'plane at angle' with 'offset plane' into one tool. Would save having to create an offset plane, then create a plane at angle to it. Would save a lot of work and streamline the design process, make it easier to change offset/angle later in the design.
much needed feature. currently its too convoluted to create a plane that is offset from the origin planes, but also at an angle. been trying to find a simple way and it's just not possible, sadly.
