I've run in to this often enough to say something, especially with contour toolpaths where I use "Selection" for my bottom height and offset -.1 to get my tool below a certain face to avoid a witness mark or cusp left from stock not cleaned up on side walls. I often have many slightly different parts and recycle toolpaths from previous parts and apply to new ones. Many instinces I use selection for heights, and the offset is never stored with the toolpath.
For example, I program a contour toolpath, select a face for bottom height, offset -.1. I then copy and paste that toolpath into another setup, select the face to use as my bottom height, and the offset value is not stored. It will default back to 0.
Can the fusion 360 team please save this offset with the toolpath so when I recycle programs the offset is stored?
This would be very convenient...
Thanks in advance
