offer left / right direction for thickness and dont use + / - values
using -3mm to define a direction can make sense but makes then the formula writing more complicated
when you want to use that dimension value for other dimensions
-3 mm to be +3mm has to written as: -(d16)
ideally if the thickness command can just use a normal value but the tool defines the direction using the surface normal as a guide
the user can later simply reference to D16 and has not to do all this other stuff
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
