OBJ export directly from BREP and TS
Fusion should also allow you to export directly from Brep or TS into OBJ.
Reasons:
Faster workflow.
Currently I need to convert TS to BRep to Mesh to export - way to much to do.
Flexebility / compatiblity: TS in Fusion is somewhat less powerful than Modo/Blender but the beauty
is to have both to work with (start in Fusion push to Modo/Blender for detailed work, bring back into TS Fusion)
Exporting TS models into OBJ is also superior for rendering because Blender/Modo can use OBJ and subdiv
to generate matching render models without meshing / heavily tesselating Breps!!!
7 Comments
deyop
Status changed to: 実装済み
deyop
We currently don't convert directly to OBJ from T-Spline but have a backlog item that would support a switch for output using the box mode (subd) or tessellated. STL doesn't support the ngons needed for subd modeling but does have the tessellation portion.
cekuhnen
TS to OBJ or anything besides STL would be great.
STL is really only usable for 3D printing and not much more.
keqingsong
Status changed to: オートデスク今後検討
colin.smith
colin.smith
Status changed to: Gathering Support
colin.smith
