NEW TOOLPATH NEEDED FOR CHAMFERS
I machine a ton of plates with hundreds of holes in them. I have templates all made to automatically drill ream tap mill these holes. Copy paste generate and post. - however I must spend a ton of time to select all the chains for the chamfering tool-path. I have tried to mess around with a contour toolpath and negative stock to leave and similar things to trick fusion into automatically generating a tool-path to chamfer all the holes but it wont let me because its an "invalid tool"
I think it would be really awesome if you could introduce a new tool-path that automatically finds top chains on the model top and chamfers them. It would also be safer because with 2D chamfer you can always accidentally run along the outside or a chain instead of the inside by just looking over one tiny arrow direction.
Let me know what you think. Probably would be very similar to a contour
