naming new sketches
naming new sketches
its a good idea you have names for sketches joints, but one thing is bad. if i make a new joint i want to be able to name it directly in that specific window where i chose the settings for rotation and offset ect.
now once i close the window i need to go to the component tree and find that last joint.  that is poor programming at the moment.
now later if a come back i do not remember what that joint was all about. so i open it. and in that modifying window where all settings are i want to also change the name. same with sketches and every thing else that can be named. thanks alot
