Multithread support for suppress and unsuppress function.
Hi everyone,
When we work in complex design such as 150 (or more) parts in one design and, for example, when we want to suppress about 75 parts. It takes time and Fusion 360 using only one thread while suppressing. I think Fusion 360 can use other cpu cores to suppress.
By the way,  I am a hobbiest programer (not a pro). I think it can be develop like this. Each parts which is the have to suppress or unsuppress can assign a cpu core.
For instance, we have 65 parts to suppress and 8 core cpu. Totall parts can be divide core quantity like 65 = x(mod 8) and x = 1
CORE 0 : 8 Parts
CORE 1 : 8 Parts
CORE 2 : 8 Parts
CORE 3 : 8 Parts
CORE 4 : 8 Parts
CORE 5 : 8 Parts
CORE 6 : 8 Parts
CORE 7 : 9 Parts ( 8 + x )
 Edit : ( Actually same multithread function can be use for hide/show function)
Best Regards
4 Comments
HughesTooling
If you plan the design you can get multi-threading see this post.
http://forums.autodesk.com/t5/design-validate-document/yellow-warning-on-component-with-no-features-...
The problem is if any part references another you can only work through the timeline sequentially.
Mark
HughesTooling
Unfourtunatly "Fusion.ParallelComputing /on" didn't work and I apology that I made a mistake. I posted this problem as a modeling issue but actually it was a simulation problem. When I try to suppress and unsuppress components in simulation mode it takes time. In the other hand, when I do this in model it's quite fast.
HughesTooling
Ok, might be worth making a thread in the design forum to get support's attention a bit quicker.
Mark
