Multiple selection in Project Tool at Sketch mode
It can be usefull to select a lot of lines and curves in Project Tool via window selection.
As for right now I have to select each face/edge/body individually. And right now having the task to project a great amount of lines/curves (approximately 200-300 lines per operation) I have to spend 10-15 minutes only for one operation to be able to see the picture of a divided face on a sketch.
The reason to select each edge indivisually is caused by a demand to export the sketch (DXF file). If I project the faces which are standing side by side, I will get two lines on the same position. It's the problem, for example, because the laser cut machine will get this as a path to cut and go through the same line two times.
On the screenshot you can see the example of sketch
Please, add the ability to select different lines and curves with a window selection to be able to select loops easier, or create the tool/algorithm which allows to reduce the appearing of doubled line.
