Multiple parts/assemblys on one drawing
There needs to be a way to open a blank drawing and then insert parts or assemblies as needed. That way multiple components can be laid out on the sheet individually in their own orientation rather than assembly orientation. It is time consuming and wasteful to have to make a separate drawing for every component.
4 Comments
Yea this, bump !
HughesTooling
Do you mean several components from a single design? If so the screencast below might help. There are a couple of ways to add components to an existing sheet, either select the components in model space and right click and select create drawing then on the dialog select your existing drawing and sheet or in the 2d workspace click base view then unselect components you don't need.
Mark
Dude thank you so much !!!
Beautiful! Thank you for the tip.
