Multi-Body Export into STL format
When selecting (right click) "Save as STL" from the pop up menu it would be very handy for this feature to be able to export multiple bodies into separate STLs. This would save a lot of time since currently you need to export each part separately.
Example: If I have selected 20 different bodies, all with separate names, then selecting "Save as STL" would save each of the 20 bodies as their own STL file.
If it is a component made of multiple bodies then there would also be a selecting option when exporting to create a single STL with all bodies or export each body as it's own STL.
 - This concept can also be applied to multiple bodies being selected and then having an option to export them all as a single STL file. Those that do 3d printing can easily arrange the bodies into a group that would fit on a print bed making arrangement in your slicer program easier given that the STL file has all the parts pre-arranged/pre-orientated.
Thanks!
1 Comment
daniel_lyall
If you select a component with lots of bodies in it and do the right click save as stl and change it to one file per body instead of one file would this help.
Also you can click at the top of the tree and do the same thing.
