I actually can't find an option to move/extend a geometry in a model like I can do it, for example, with "move face" in solidworks, but there is in almost every cad program, which usually call it"extend feature".
I make an example to make it clear:
I have a sheet metal with holes. if I presspull one of this hole, i can't move it in the space, but i can only offset his value, if I choose to use "move" feature, it can't let me choose faces, but only body or component to move.
Another example could be a piece where you want to reduce or enlarge a side, literally extend it, so also in this case i can't find a way to do it.
Actually I have to do this thing only with sketch tools and a lot of wasted time, and when you have your sketch is quite easy, but when you import a file it will make you crazy.
There is the possibility that I can't find that feature, but if it really doesn't exist, I think this adding could be extremely useful for a lot of user.
Many thanks
Alberto
