t is great we can use the direct modelling with the move/copy in the history based environment.
Nice that you can move faces from several bodies or even parts (after window select); this is a big improvement over the direct edit tool in inventor.
See for example this:
Direct editting
These things would be nice to add:
1
The direct edit changes should be captured in parameters, so you can change these again. This happens in inventor, but it would be great to have this in Fusion.
2
We can move features/faces to another point. I would like the abillity to move them also to some offset of a plane. (This is also possible in inventor).
So it is nice that we can direct edit several parts and bodies together, but the few things in Inventor which are extra over Fusion would be nice to add to Fusion also.
