Move Command Should Retain Position
When editing the "Move" command in the timeline, the displacement is always reset to zero. This doesn't make any sense... in parametric modeling commands on the timeline should always retain the number that you entered.
1 Comment
HughesTooling
If you use the translate option the position is recorded. Seem to remember when the parametric version of move was first implemented it was fully parametric and lots of people complained so the non parametric option was brought back. Personally wouldn't notice if move was removed from Fusion as Joints do a far better job as the position is then linked to a point and updates if the model's edited. I think the move tool is pretty amature and should not be used if you can help it.
