Mouse sensitivity options/drag strength
Hi guys, this is mainly for the sculpt T-Spline environment, but could also be useful for control point manipulation in control point splines. When trying to make really small adjustments to a T-Spline edge or vertex the standard mouse behavior in a lot of cases is too fast. It would be great to have the option to adjust the mouse sensitivity while making those adjustments.
This is quite common when modeling with control points. This was available in the original T-Splines for Rhino as the multiplier and it's is also a setting in that can be adjusted in Alias among many others.
