The fusion 360 sculpt mode is not bad but it could be even better with some improvements. The marquee select is very inprecise and grabs vertices that were not in the selection box and has a mind of it's own when deciding whether to select vertices or the curve control points(forgot the name) I've included a video to demonstrate what I'm talking about:
Other improvements I'd like in the sculpt mode is some kind of keyboard shorcut for edit form tool as it's the one I use the most frequently, as well as needing to leave edit form tool to access other tools like crease/uncrease edge, insert edge and etc. Shortcuts for these common commands would be very much appreciated as well. Thank you for your time.
