Minimum retract needed in Drill and 2d thread.
I have run into an issue with 4th axis machining.  Once a drill or tap operation is done the z moves clear up to Z home before rotating to the next hole location. This uses up a lot of time.
I am assuming it is not obeying the retracts heights tab.  I also assume a minimum retract would fix/patch this issue.
I ask for the minimum retract option in Drill and 2d thread.
